reidy.mk5
I was wondering if anybody has removed there aerial from there car ive tried today but it only screws off so far then nothing i dont want to pull it or anything incase it breaks
I´m thinking about changing my aerial as well.. The "anti-theft-lock/jobby" on the aerial, how does it work? Can you just replace the oem aerial with another one with the same threads on the "bolt" or am i going to have to change the "foot" to be able to put on an aerial with another design?
If your replacement aerial has the same thread it should just screw in once the old one is removed.
havent had it done, tried to get to the bolt under the head lining but, just too bloddy hard..the lining is very fragile and creases very easily. not sure on where to go from here
