afr, whats ideal
ryan_s3
1,270
12 for best power
11.5 for best torque. I personally wouldn't map anything above 12's on full boost
20vpolo
57 Leon FR TDI
Sep 2, 2008
61
I map mine for 11.5-12 on boost but always add a bit more fuel in right at the top end 7500 rpm + and 13-14 off boost.
gazcuprablk
my 300+ death box :)
Mar 31, 2006
858
south wales
i had mine rolling roaded on the weekend at gotboost in south wales, mine is at 12-11.8 when at 3k and drops to 10.6 at 7k but drops to 10 at 6k so is struggling abit on fuel the guy said the map needs a little tweek but i think its because i have 440cc injectors runnin a 3bar reg so im guessing i need bigger injectors or maybe 4 bar reg? also have walbro in-line 255lb pump.
they used a dastec rolling road are these rolles any good? as im new to this rolling road stuff.
20vpolo
57 Leon FR TDI
Sep 2, 2008
61
Its not struggling on fuel as its running rich at the top end!
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Run times on Dastek were an issue as they were fixed rpm/sec acceleration and load applied as far as ecu was concerned was quite different to real road... maybe they have changed this.
top end fueling is rich, but EGT's at that level is also a factor... (as well as the code which is on the car - which I do not use anymore for stage 3 btw, due in part to this kind of top end richness for no good reason)
Badger wagen is running 12.0-11.5 top end fueling... 9000rpm, 35psi boost as a guide to what produces good power.
gazcuprablk
Mar 31, 2006
858
south wales
wel ill be at castle combe for the vw audi trackday next weekend so ill pop over bill show you the graff, that reading was taken on theyre guage not the one i had off you bill as ive still not fitted it lol
