Air blowing through interior vents on boost?
platofan
218
I seem to be getting a whistling and a breeze of air through my vents when the car is on boost. I also think something's up as the coolant temp is hitting 90 pretty quickly.
Only started today when I took the car for a run and the only thing I can think of is maybe a pipe has popped off the intercooler/turbo?
Any ideas?
MJ
Public transport abuser
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
Let the coolant cap off a few times to make sure it has bled properly, as for your vents? a turbo pipe off would cause then engine to over fuel and throw loads of black smoke out not really blow air through the vents.
platofan
218
Found this
Originally Posted by superleon1
Sounds like it could just be the boost pipe attached to the intercooler coming loose? A common problem...had it recently myself...just got a jubilee clip and clamped it together...no problems now....half an hour to fix....it could be your turbo going but unlikely with that low mileage....do you notice a whoosh of air coming in the driver's side air vent when you accelarate? If so, that's your best bet...
Sounds like my problem. Seat specialist said a pipe did pop off a few times but they clamped it and I suppose it's just made the next weakest pipe pop off now.
One thing after another with these cars lol
MJ
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
Tou will only hear a noise not really feel more air coming through unless you increase your speed and it will be out side air passing into the vents not air from the leaking pipe.
platofan
218
I think the temp thing was just paranoia....yesterday was hot. :)
Took the undertray off and there are a couple of connections that are still holding but have a fair amount of play in them. Could I still be losing air out of these? One is the very bottom 90 degree joint and the other is on the end of a metal pipe.
Forgot to mention that bottom 90 degree one drips oil from the joint :/
