Good evening all, first of all, this site is a gold mine of information!
I love my Leon and I only have the air con left to fix to make it perfect. I've had it re-gassed, twice just to be certain. The fans both kick in when the AC is turned on, the clutch also engages and starts spinning. As far as visuals go all seems to be well.
The air that's comes out is not noticeably different to LO without AC. So I did some digging on here today and discovered the climatronic built in re-circ diag thing. I figured check the compressor rpm and see what is going on. It came back as a 0. So I thought reading that clutches fail, check the voltage going to it. Came back as I think 13.7. So I did the channel 52 compressor switch off codes. I had no decimal which seems to indicate the compressor is off. The only other thing I had was a little 0. No dash through the middle so where you have 00.0 I just had the last zero. I'm slightly confused as to what that all means but not having the decimal, would this suggest the compressor is not being allowed to turn on as opposed to it just not working. Or is this going to be a VAG com search?
Once again, great site and I'm hoping there's an AC guru out there!
Thanks.
Thanks.
