airbag question
Chris Cupra R
158
Bournemouth
when i riped out my front seats i removed them then replaced them without turning on the ignition so i didnt notice if an error would come up.... if i get new seats without airbags and install then and drive with them in will this have a horrid error light on my dash... just woundered as well i i need to save weight and replace the cupra seats with carbon firbe ones he he :D[B)] :p
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
yes the light will come on, i think some resistors will be needed, when i changed my steering wheel i had to put a resistor inline to confuse the ecu.
Chris Cupra R
158
Bournemouth
humm cheers for the info... wot value resistor and did u just bridge the resistor accross the wire that went into the seat.. my only concern is incase all of a sudden the airbags go off for no reason.. and rip apart my dash...
cheers.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
the airbags wont go off for no reason, and wont rip the dash apart, i dont think the curtain airbags reach that far, not sure on the resistor it came with my steering wheel boss, email momo that was where i got my boss from they will probably know what resistor you need and may even supply it in a kit.
Chris Cupra R
158
Bournemouth
a resistor is a resistor.. like 18p from maplin... ... do u know the colours it had on it.. like the stripes going around it? ill e-mail momo too! cheers buddy.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
not sure it had heat shrink over it, id check but it was a pain to remove all the bolts on the wheel.
