Aircon not changing temperature between 18-22
BYKjaer
11
So recently i discovered that my AC gets really hot when on 26, but when i turn it to 22, it gets really cold and there's no difference from 22-18 degress, so it's basically 18 when it's turned to 22.. Would a recharge do it or is my ac unit just old and broken? It's a 1P 1,9 TDI with the old AC unit with the 3 knobs that's not automatic.
joshwill
12
South East
I had the same problem with mine but I had either cold or hot and no in between. Turned out my condenser had a hole from a possible stone chip and was leaking gas. Had it replaced and re-gassed and now it works fine with temperatures back to normal.
Fuel for thought if your could be a similar situation.
BYKjaer
11
Oh okay. Bye the condenser you mean the radiator in the front right? Will have a look at it. Discovered that there's no in between on mine aswell. Cheers man!
joshwill
12
South East
Yeah that's it. Hopefully you can see the shiny new one on mine.
