Alarm HELP
STOCKY
Audi TT 225
Oct 6, 2004
1,005
N.Ireland
Fez boy said:
TDi Mk4 can you turn it off [:@]
It's been rewired on warranty but keeps going off every 1/2 hour :censored:
long shot here
pull the fuse out, if there is one? Check the fuse card in the fuse panel!
Im not to clued up on this so dont take my work for it!
Disconnect battery??? Make sure you have radio code!!!
andy_gdon
494
Is yours a FR or sport?? and have you owned it since new??
If not id put money on it having had an after market alarm poorly installed/uninstalled. Due to the fact your standard alarm is CAT1 most after market CAT1's seem to give it trouble. Unplug your interior sensor, or try turning it off as i said in the other post.
Fez boy
560
Watford
It's a sport(and yes it's just gone 5am :censored: alarm)
Have tried all the things that I did before last problem but nothing works?
The alarm IS the factory alarm as the dealer only sorted it last week(or so it seamed)
I'm going to drive to the dealer this morning and leave the car there so they can look at it again :rolleyes:
mrcoyote
See no evil...
Jul 26, 2004
2,624
I know this might sound unrelated, but does your rear wash work properly? Get them to check the pipe as was half off and the pipe inside the motor was leaking as well which caused water to run down the tailgate onto the sensor.
Come to think of it, the internal sensor and bonnet switch was replaced at the same time so it could have been any of them. :shrug:
