No. Mine keeps say issue with order or payment despite adding 3 different carddHas anyone with a MY22 car (using software v1804) managed to get this to work?
I can download the app through the website, I get both emails saying it's activated, I get a message in the car saying the app is ready to be installed from the store but when I go to the Store it's completely empty. Everything is connected properly (I can lock/unlock the car from the app for example), I'm using a hotspot or wifi in the car and still nothing.
I had that same issue, it was because something wasn't correct in the Seat ID settings from when you initially registered. It had my ID number (Spanish) as Other, when I changed it then it workedNo. Mine keeps say issue with order or payment despite adding 3 different cardd
Ah, I shall have a lookI had that same issue, it was because something wasn't correct in the Seat ID settings from when you initially registered. It had my ID number (Spanish) as Other, when I changed it then it worked
Not sure about update but I tried again from car and Alexa downloaded and installed on mine too!I just received another system update (second today) and now the store seems to work and I could install Alexa at last!
i use the same method works great as long as you have a good 4g signal.If anyone uses Alexa for music etc I have just managed to set this up using the app in the car and my phone's hotspot with an app that turns the hotspot on and off automatically when it connects and disconnects from the Bluetooth. After a day it's still working ok.....
It's nice just to ask for any song and off you go
yes mine is working fine ..Has anyone with a MY22 car (using software v1804) managed to get this to work?
I'm the same, I use Google, can control via voice, streams from Spotify on android auto without any issues.see my other post from today for using Alexa.....i now don't bother and have started using Amazon music .i use google for everything else as its far superior to alexa in every way.this way i don't need a hotspot as its on my phone on android auto. i get the same results but faster and more reliable.
Anyone know of a iOS equivalent to Carspot Ready which is for 'Droid only?Carspot Ready. It's been working really well and just runs in the background on my phone and then vibrates and plays a sound to say it's connected.
I have added a short cut to the Alexa app to the icons along the bottom as I am finding I need to press it once to launch it but once it's launched it then works off your voice
Yeah I believe soI've installed Alexa and got it working, but to do so I'm using a WiFi connection via my phones hotspot as Alexa won't work via the built in eSim.
As I'm connected via WiFi, the system says the eSim is disabled (or turned off), does that mean all downloads, updates, SOS calls and everything else the eSim is used for is now going through my phones data package?
OK, bye bye Alexa - unless someone has discovered some amazing (car based) functionality I couldn't live without? I use Alexa a lot in the home for various things, but can't see much value add here and as I don't have driveway gates to open on voice command as per James Corden in the new RRS launch video...Yeah I believe so
