Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Just found these clicky They look to be the same as the Carmodshop ones that are out of stock? Anyone know if they work?
These are marked as reversing bulbs, I guess they will be OK as sidelights?
Sidelights (501/w5w type)
These were relatively easy. You can buy 'canbus compatible' LEDs of many flavours now, but I still had some plug'n'play resistor cables that I took from my FR when I sold it, so I've used those in my Ecomotive, together with some Philips 4000K LED 501s. They are a decent match for the bi-xenons. Maybe a tad warmer white but close in colour, and importantly they don't have that obviously-after-market look and make the reflector blue when they're switched off like the 501 bulbs with blue glass do.
Yes (or get 'canbus friendly' ones with the resistors built-in).Do you need resistor cables in Leon 2009 FL ?
I've just been trying to view the alternative canbus-compatible 382 module from ultraleds.co.uk (as linked by Nath above) but it's showing page not found so I guess they're also out of stock now...
If anyone is still having trouble sourcing some white canbus-compatible LED replacements for their facelift DRLs (382/1156 bulb type), I just found these:
http://www.car-mod-shop.co.uk/Canbus white 27 SMD LED BA15s 1156 382 bulbs
They look similar to the ones that I have, but these new ones also have 3 SMDs pointing forwards as well as those mounted on the double-sided crossed PCBs. Might be worth a shot?
