Alloy wheel refurb - polished lip
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Hey guys
As some of you may have seen, i recently got some 18"s back from the powdercoaters. I asked them if they could spray the spokes, but tape up the lip so i could polish it up. The wheels were originally silver with a polished lip, but were sprayed black when i got them, and i have since got them done in red. Only problem is that when the guy took the tape off the lip, some of the tape got stuck on, and it looks like some of the lip has got some overspray on too. But my major concern is that the lip seems a bit pitted. I've tried with a few different grades of sandpaper, but it doesn't seem to be shifting. Anyone recommend some stuff i could use to get it back to how its meant to be?
Aug 24, 2007
800
what grade are you using ?
I'm doing a set of TSW legends at the moment that have some nasty lacquer corrosion. Start by giving the lip a scrub with soapy water and then polishing with 800 grit wet n dry.
Takes a while to start eating in to the lacquer but it does suddenly start to cut in. Once the soapy water turns black move on. Takes about 10 minutes for a 2 inch area :cry:
Then polish up using 1600 grit upwards .
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I've been using 320, 600, 800 + 1200 so far. Just isn't shifting it
stay longer with the lower numbers, like paint the polished surface is only as good as the work on the foundation
if you still can't get the pits out with a 320 then they are too deep and probably want machining out
one way that helps is a post/pole with an old wheel hub on it or make one outta wood so you can spin the wheel round and round - lot more even
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
I'm not bothered about the tape, and i don't think they caused the pitting. I'll persevere with the sanding a bit more
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I would say they shot blasted the wheels before they powdercoated them and thats why they are pitted?
Ideally they should have had the lips polished first then masked up and sprayed instead of coated.
If they have been shot blasted I don't see any way of polishing them now they have been powdercoated.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
They were sandblasted ;)
Think i'm gonna give one wheel a real good going over tomorrow, and see what the results are. Only other option is to spray the lip another colour, but can't think which one. Already done a photoshop with black lip, looked proper cack
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
never too bad to save - always put coloured gator trim on you can try all colours then :):)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
What about sanding them as best you can then high build priming the lips and paint them an off white color?
You'll never polish them up to the painted edge without taking the powdercoat off unfortunately.
Or take them back and complain, they might redo the whole wheel in red?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Yeah I reckon so mate, you can actually get a chrome paint but for it to be effective you'd have to get a nice smooth silver finish first then apply it over the top.
To get shot blasting marks out you can go quite a bit more coarse than 320, I'd use 120/ 180/240 then what you have been using :)
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Ok mate, cheers. Looks like i'm gonna spray them then, just gotta be careful to cover up the newly powdercoated centres lol
