Hi. Can you recommend n alloy refurbishment company that can refurbish 1 x 17” seat Leon alloy to factory finish? Preferably same day? I’m based in Slough
My tip is to buy a spare alloy. The boot of the ST takes a full sized wheel so add a jacking kit and you're carrying a spare wheel instead of just the crappy foam.
Once you've got your spare you can put it on the car and sort out the damaged wheel at your leisure. Even do it yourself if you're up for it.
If you want factory finish, then you'll probably need to be without your wheel for more than a day, although length of time to refurbish will depend on what needs doing - e.g. purely cosmetic refurb won’t take as long as removing / repairing cracks or buckles, followed by refinishing.
If I was in Slough, I’d seriously consider using Lepsons. They’re in Gillingham, so its a few miles away from you, but they’re meant to be one of the best in the business for alloy wheel refurbishments so you should end up with a factory finish. They get good reviews on some of the VW forums too.
