Alloys for her Bammer??
mrcoyote
See no evil...
Jul 26, 2004
2,624
They all look a little odd on a 'bama tbh and you'd also have to lower it a bit with the lower profile tyres otherwise it would look like it's on stilts. If I had to choose, I'd go for the original set rather than any of the Audi replicas as they look a little too chunky if that makes sense.
Forget the Toyo's they wont last :( they are not rated for the Bammer which should have Re enforced tyres due to the load! been there done that and gone through a set of tyres in less than 10k :(
as for the rims they look nice :D but the spokes stick out past the tyre/rim and if your other half is like mine they wont last long [:@]
mine are in the garage awaiting a refurb :cry:
for an idea of what rims look good try here http://www.wheelmachine2000.de/
use the VW Sharan as the bammer section doesnt show the rims on the car :(
MARKYB
65
I have both had both Toyo T1 S's and Toyo T1 R's
The T1 R's are more expensive, by a tenner, but are reinforced walls, and a harder compound, the T1 S's are softer, better (looking) tread with more sporty pool, the walls, not being reinforced means that the tyres flex when under pressure, but its good if you want to maintain control as the tyres flex instead of stepping out, but when you go past the limit, it goes big style by comparison. TI R's are safer bet, for long termness.
The T1 R's being re-inforced, mean you can run 10 psi less on a track day and they still stay on the rim till temperatures increase... which means optimum performance, optimum psi at peak temperatures!
So im running about 250 Bhp through front wheels, top whack 165... these tyres are great! T1 R's, they are the newer design also... ;)... good luck...
Stu B
DarthWombleIII & WombleII
fredt - cheers - concept back on hold ... was concerned about the load/re enforced issues...
jase750
662
Stoke on Trent
Premier in Stoke have a VR6 Bammer with 19"s on ! ! It looks awesome I think they put some Cupra R brakes on it (or painted the calipers red).
They look like they came off a Cayenne or something like that.
So aslong as you like them I would say go for it ! !
