54 plates. 2.0 lite TDI, DSG, 94,000 miles. New engine management unit (ECU) and stability control - the latter was the most expensive thing. Passenger window motor. Front spring although I did do 1,000 on it broken that says something for German engineering. Normal disks and stuff, bulbs and faulty holder not making contact. Wiper you do yourself buying the fronts off internet, back cut to fit.
Exhaust pipe has never dropped off and is original - kind of expecting the exhaust pipe to go but it's original. I keep the aircon going myself by pulling the fuse and putting it back in - the main AC motor compressor fuse under the dash heats up, bends the plastic, gives spurious contact during hot or cold spells which then cause it to stop. I reboot it by pulling the fuse out with ignition off and pushing back in. When sufficiently dis-formed I change it. Done that twice - last time I did that the fault, it had fooled so it appears a distress mode of operation - that I reported here (nobody posted against it so must just be me who's had the issue). Changing the fuse and a few days fixed that mode of operation - light turned on all the time etc, whatever I said on that thread.
I would say that
repairs can be expensive but that is the way of the world - ECU and ABS unit. Think Honest John said there was a bug on one of these and you should argue with your
garage on this, several years back but I had, had mine done when I read that. The car was looked after by a fairly decent
garage for most of it's life but having moved the
service 60 miles south the "new"
garage I've been using turn out to be jokers (clue nice people you don't want to do business with - they bodge), choice of Seat garages round here aren't great if I want to use my London transport pass to get home
. Seem to have a choice between bodge
repairs that might hold or franchise prices with a bit of driving, bus and train ride to get home which isn't in my free zone ):. One of their bodge
repairs held on the indicator bulb fitting rather than a new one (best described perhaps as an Indian repair), their other "Indian" repair I believe was a glueing the turbo pipe on instead of using a clip since they didn't have one which I believe is what they did, rendered the car un driveable as the pipe blew off as I started it up - returned to my door like that after a
service and MOT. Truly jokers. When I took it in on the pick up they said do you want us to make a temporary fix or leave it here so we can order the parts - thought yeah, it blew off during the smoke test and you repaired it once and we know what happened with that repair that you didn't let on about. So I'm more concerned about finding a reliable
garage that doesn't provide third world bodged
repairs, especialy if I'm going to buy an
Ateca. Might have to settle on travelling 20 miles for
service.
