Hi all,
I've got an Altea TDi FR which has had some long running intermittent faults. The fault is that it goes in to limp mode when I switch the car on. It never comes on during driving and I can clear the fault by either switching off/on or driving for a few hundred metres and off/on again.
History is:
- First dealer visit reinstalled ECU software
- Second said that the boost sensor had failed and this was replaced
- The fault came back along with a cruise control intermittent fault so it went back into the garage for "deep diagnosis" + new software install.
- Fault came back again and I had a new ECU installed. Cruise control fixed
- Fault came back so it went into the dealers for 5 days where the software was installed x3 times and road tested, no fault found.
- Fault is now back again and cruise control is also bust, so I bought vag-com with a view to getting some more expert help i.e. you guys.
After a reinstall of the ECU I get around 2 weeks of fault free motoring, but then the faults come, and now the fault appears every other time I switch the car on.
This is the autoscan log -
None of the dealers have mentioned the MAF problem that vag com found. Surely their machines would pick this up? Or is it something to do with the way I've scanned the car i.e. engine not running?
The car is under warranty but the dealers can't seem to work out how to fix it. Any suggestions? Also what are the mileage figures for the sensors and why are they different?
My vag-com experience is approximately 15 minutes, but I can pop out and get more logs if needed.
Thanks in advance,
Jon
History is:
Code:
VIN: Mileage: 28490km/17702miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 018 EC HW: 03G 906 018 EC
Component: R4 2.0l PPD1.2 G 9583
Coding: 0050072
Shop #: WSC 02108
2 Faults Found:
005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
P1592 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 5
Fault Frequency: 22
Reset counter: 40
Mileage: 28231 km
Time Indication: 0
Date: 2000.00.00
Time: 10:47:27
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 11.87 V
Pressure: 1001.1 mbar
Pressure: 1469.7 mbar
000257 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 38
Mileage: 28419 km
Time Indication: 0
Date: 2000.00.00
Time: 18:25:04
Freeze Frame:
RPM: 1376 /min
Torque: 0.0 Nm
Speed: 47.0 km/h
Temperature: 30.0�C
Pressure: 1299.3 mbar
Text: 76
Text: kg/h
Readiness: N/A
Thanks in advance,
Jon
