dizzydiesel
Hi folks,
Think my alternator is goosed. Does anyone know what part number replacement I need?
2001 Toledo 1.9TDI 110bhp.
What current rating do I need? 90Amp?:think:
I think its a BOSCH unit....but haven't had a chance to check it yet.
Thanks.
Quick auction search found this info:-
TECHNICAL INFORMATION
VEHICLE MANUFACTURED DATE RANGE
11-1998 ~ 9-2002
PART NUMBER
FRA338
MORE INFO 1
1.9
MORE INFO 2
TDi 110
MORE INFO 3
ch.1M-X-000001-
ENGINE CODE
AHF
ENGINE CC
1896cc
AMPS
90A
Application Advice=Clutch Pulley
Hand of Adjusting Bracket=DH
ANITA
Nominal Voltage (V)=12
Number of Lugs=2
Output Current (A)=90
Pulley Diameter (mm)=56
Pulley to Front of Mount Distance (mm)=26
Pulley to Rear of Mount Distance (mm)=40
Pulley Type=6PK
Regulation Type=Internal
Terminal Configuration=B+ (M8), L DFM (2 pin plug)
Warning Lamp Terminal Type=1.8mm blade
there's a few and then some to choose from so do you know ya engine code at all ? AHF / ASV ? you'll also need to look at it if possible to help narrow it down
AHF
70A Bosch
90A Bosch
120A Bosch
90A Valeo
120A Valeo
ASV
90A Valeo
120A Valeo
that lot should open ya options up a little as each one has a replacement and/or an exchange unit also listed and there's not to say they are all interchangeable of course but a good rummage with a torch and mirror will narrow it down a bit
Thanks guys - that helps a lot.
Probably going to get a refurb kit and replace the bearings and brushes.
