Vagcom but cant remember which block. You can see how much they are injecting. etc..
Must be massive over fueling
any ideas how i can find out i have the correct tandem pump fitted to my engine , as i had one replaced when the whole shamonga happened
as their on ebay for £50 used , thinking is it worth me getting one and take a chance ,
as some descriptions state they cover a whole range of part codes ?
also this jerking has started more now , seems lower down the rev range , and seems as if it down want to rev much further than 3 -3500 rpm
put some millers in yesterday and most of it seemed to have dissapeared again , not sure if theres $hit in tank , ?
ive just ordered some bits from tps
oil 19.35
oil filter 2.60
fuel filter 10.15
total inc vat was £38.52
so thats on the to do list .....
any ideas if a neuspeed rear arb is any good , and how much they worth second hand ??
also found the new part number for the tandem pump 038 145 209Q
will search for a pump on that number
well took the plunge and did the service
also bought x2 wynns injector cleaner and filled the fuel filter up with them instead of priming with diesel
then bought 10k boost to spray in intake to clean up
got to say car feels much more responsive
car also hit 90k
after hols il buy the tandem pump for it too
not much to report apart from i took my roofbox and bars off after a month :)
cars done about 92k now
its been suggested that the valve stem oil seals may have worn / gone ,
allowing this to pass through , im no expert so its like pi$$ing in the wind to me
should start a new build thread on my van i bought kitting out as a race camper van for my new hobby motocrosss
seems to be taking up my time at the moment
what bike you got?
i got a trailer last year and was close to buying one, but seems theres nowhere to ride :( want a kx125
will get one sorted
four stroke all the way
YZF 250 07 model
i also have a 10 plate XJ6 roadbike (600cc )i bought last year but not got much time for that lately
its only done 2400miles since i bought it new last year !!
as for mx tracks check my friends website out usually has a track close by
http://www.mxpracticetracks.co.uk/index.aspx
Also found a new product for cleaning i bought at a mx race meeting called Rhino Goo
the guy who owns the company is from abergavenny and its getting massive on the mx scene
i washed my mx bike monday , van tueday and done the leon last night , i sprayed it on the wheels and exhaust and all the clayed on soot & brake dust just fell off with no effort or aggitation required
so heres one for Maz to check over as it says no harmfull chemicals to destroy things with
http://www.rhinogoo.co.uk/
car also hit 90k
well its been a while now , car is still smoking , seems like 50 fags a day !
its hardly used any oil since the oil change plus i never checked it after the change :blink:
checked it last night with a bit over 92k and on the dipstick its still 3 quarters full of the min/max so cant seem to be using much oil
also finally glued my S badge back onto grille and fitted back on last night
gota pull my finger out now on the small things that need doing :whistle:
