Ok since I had my car mapped last year everytime im at full boost high in the rev range in 3rd or 4th gear for a decent period of time my car jumps in to limp mode 7 psi boost and reduced power.
I fitted an n75j after my rebuild this hasn't cured the problem. All my vac hoses are brand new and I have also fitted new intercooler and piping. So I can confirm there's no boost leaks.
Here is what Ross-tech state:
17964/P1556 - Charge Pressure Control: Negative Deviation
Possible Symptoms
Reduced power output Limp mode
Possible Causes
Boost Pressure too Low Hoses/Pipes incorrect connected, disconnected or leaking Charger Pressure Control defective VNT (variable nozzle turbo): nozzles stuck Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components Check Solenoid Valve for Boost Pressure Control (N75) Check / Clean / Replace Charge Pressure Control Check / Clean mechanism for variable nozzles
Can anyone help? Could this be the map?
Sean's Xperia arc
Possible Symptoms
Possible Causes
Possible Solutions
Sean's Xperia arc
