i get it when i take my key out of ign before leaving the car had it on both my ibizas both 62 plate and dealer said it was normal and if i wanted it to auto lock above 10mph needed to be turned on with vagcom
You can turn on lock above 15kmh without VAGCOM.
I've done it but as it was a one-time thing you'll have to look in your manual or Google it, unless someone here remembers from memory. :)
The deadlock message is normal after switch off but not while running, it's just a reminder to make sure the remote locks (put on the handle).
the auto lock function is in the manual, I've managed it on a 12 plate se version.
You hold the lock button in and turn the key 1 click then hold for 10 seconds and let go.
It some thing along those lines
