Any1 got a spare n75 valve I could try in westyorkshire please?
mill5y
190
sheffield
That was the first one I re found but yea check there's no crap in there and that there is a vent to release any pressure.
If it's coming off and your only running 3 pots that's enough to cause a misfire?
b3nm33
213
When accelerating at around 3-4k I holds off boost and back fires then it will pick back up and take off or go in limp mode.
Longy82
372
West yorkshire
Mine doesn't lift that far as the plug is tight so that stops it luckily but will take mine off again tomoz and see whats going on again with it.
Longy82
372
West yorkshire
Never thought ov that Ben what mill5y just said I didnt no yours lifted aswell :/ that could be the problem well that's if it not like mine were the plug stops it from lifting right off
ScottyBoi
Leon Cupra 180bhp
Feb 8, 2014
101
Sheffield
That's strange, due to backfire it's got to be somet to do with your coil packs etc but you've changed them so I can't see why it would be still doing it.. Have you had it plugged it mate?
ScottyBoi
Leon Cupra 180bhp
Feb 8, 2014
101
Sheffield
Tbh I've just thought If it's boosting then stops and backfires then it's got to be a coil pack lifting then going back down if it continues to boost after ?
b3nm33
213
Yes mate it's been plugged in mate and the only code that stays is the 17705
b3nm33
213
But I had a mates set of coilpacks in the other day and didn't ever make it out of his street before it did the same thing.
ScottyBoi
Leon Cupra 180bhp
Feb 8, 2014
101
Sheffield
That ****ing code gets to everyone! You could buy the coil bolt downs and hope it cures it don't want to waste money for nothing mate
b3nm33
213
My boost gauge is very erratic 2 though it will boost to 25 psi then drop right off and boast again. That's what was making me think it's the n75.
b3nm33
213
Nope they where fine took them out and put mine back in as the fault was still there.
Longy82
372
West yorkshire
Mine pop up tho and I don't get any backfire mine runs perfect till it goes into limp mode then turn off back on and it's fine again so his carnt be owt to do with his coil packs :/
ScottyBoi
Leon Cupra 180bhp
Feb 8, 2014
101
Sheffield
Yeah mate mine does that, about 2-3k it doesn't boost or sometimes hesitates to boost then will get through it.. What I do sometimes if it starts to do it turn car off then back on and it stops doing it until it notices to do it again I've done all sorts to mine, new plugs, checked and replaces pips etc, n249 bypass so the only thing It could be is n75
b3nm33
213
Badger 5 told me £60 + vat and he will do pressure test smoke test and dyno. Gotta book it in though as he lives an hour and a half away.
mill5y
190
sheffield
Check your maf too,
Had timing belt changed?
Your coming on boost ecu adjusts and if your slightly out of timing the adjustment throws it way out causing the misfire.. Check your plugs, it's show which is poor firing. Also can check misfire on bag com tell which cylinder it is
b3nm33
213
Not got vcds but got a vag handheld and the last time it did it it gave some codes. Not sure about the timing how can I test that.
ScottyBoi
Leon Cupra 180bhp
Feb 8, 2014
101
Sheffield
If I was you mate I'd have a good look round yourself first check under the inlet manifold, the pipe that looks like a Y pipe that connects to your head it's connected to 2 other places but easy to take off n back on mate, have a look under car at pipes, just take pipes off that you can see n make sure you put them back on properly..
b3nm33
213
