Once again I'm stuck lol
I'm just about to fit the front hubs, lower arms, steering rack and ARB from a mk1 TT, all this should be the same as what is standard on the mk1 LCR albeit to different spec (bushes), problem I've got is that my standard setup uses drop links from ARB that bolts on to lower arm but new setup drop links bolt to top of the shocker assembly.
I either need to fit the front strut from a matching vehicle or possibly weld a mounting bracket on to my existing strut to secure the ARB to it, or I was wondering if it is possible to remove the shocker from the strut and refit my existing shocker into an S3 or TT strut? I seem to remember that the struts have some sort of "cap" on them which look like it may unscrew?
My car by the way is a 2004 Leon cupra tdi.
Any advice peeps???
Any advice peeps???
