Lee C
44
Barnsley
As title says really, is there anyone around my area with VAGCOM who is will to give my car the once over and prehaps shed some light on my boost promblem.
Beer tokens are availiable:D
Lee
Lee m8, there are a few of us, unless we scared you off with the mini meet!
Tho it was cold, and I was in a rather boring mood due to work, we aint normally that bad, honest :D
When are you free?
No You did'nt scare me off, the cold did though.
Im free anytime after sunday, this limp mode is starting to get on my nerves
If you are willing to travel to York ill read the engine fault codes in it nps .
Or i have a m8 in wakefield that may do it for you as well.
Poss sounds like another inlet pressure sensor fault ,, ive done a few this year :(
Car is ok when you first switch on ,, then after a boot full she goes in limp ??
Car is fine but will only boost to 15psi and then when you put your foot down it just jumps into limp mode.
Ok, could you PM me your post code to see how far i have to travel and how much.
I just want to get this sorted now
Lee
Hi
My full address is on my web page under the contacts bit
The cost = FREE :)
I will read the fault codes on the engine no problem this only takes a few seconds ,, regarding repairs we will go from there.
If any parts are needed most parts are best of from the main dealers so you can get them, and then i dont have to make ££ on the part costs. :)
I think you are about 30-40 miles from me
Regards bell
Is there anyone who can sort my car out and plug in vagcom for a look asap.
Could do eith someone local as the car just aint running right at all.
Edit,, ive not got my cable with me :(
Im after someone local Bell beacuse the becomes hardly drivable so i cant really risk the 30 miles ish to you.
If your ever in the area i dont mind travelling a bit but im in fear of the breaking down completly.
Lee i just need to get hold of a laptop and i can give you a hand, sounds like a tall order but fingers crossed should have one by the end of the week.
I'm in Doncaster and have no worries coming to find you :)
I'll be in touch.
