anyone know how to adjust the choke??
captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
my car will only idle properly at 900 rpm when the car is warm. stepdad has said the auto chock does not come in un till the car has warmed up. i got a vagcom lined up and one of the codes was the throttle positing and i want to set it up properly and dont no how,
anyone know how to do so??
robreidmotors
RobReid
May 10, 2008
677
Lancashire
All the cars running is controlled by the ecu, so there are no adjustments.
Do you have the fault codes that came up?
Its going to be something like a faulty sensor or bad wiring to a sensor giving bad info to the ecu. Or it could be a vacuum or air leak, bad hose etc.
captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
u can set it via vag com, so i have been told. think i have a bad temp sensor which i need to chance jus cant be arsed forking out 8/9 quid for it at gfs
