anyone know what the thing is with cups on called that the driveshaft goes onto
southard
11
as above anyone know what the cup things are called that go on gear box they hold the drive shafts on with 6 spline bolts the cup goes into gear box has like a shaft on one end and cup on other which drive shaft bolts 2 anyone know propper name for this as i have managed to crack mine after doing a single fly wheel conversion i dropper gearbox
Fmxvxx
388
Not sure on there "proper" name I've always called them a flange and the N/s flange should be removed when dropping the box ;)
southard
11
do you know where i can get one or have link on ebay i need drivers side one
southard
11
what about the middle bits in the cups with the splines on what are they called
mty12345
3,771
476
bristol
I'd call them inner and outer cv joints, inner obviously being the one on the gearbox side
