Tosun
17
Found some rims for my wintertires.Not sure if they fit??
Oem rims are 19x8 with ET45,,245/40/19 Tires.
New rims are 19x8.5 and "ET 35",,245/40/19 tires also.
Seller was not sure also if they fit,talked through phone.He said maybe rims hit calipers and stand far out .Anyone got this numbers on their rims??
Rims in link
Wheelfitment.eu or willtheyfit.com
Will they fit you can put in the offset and size etc and tells you all the movement and speedo difference
Reactions: Tosun
Thanks,,I have Will they fit in bookmarks,great site.
Its says rims will poke out 16mm more than with Oem rims.Thats alot,and if I fit 10mm spacers that I have in garage.Almost 30mm against OEM.
Think I will hunt other rims ?
16mm is nothing! Especially in a car like ateca. Hang some string from your arch to use a dumb weight. Then use rule to measure to centre cap I reckon you got least 25mm arch to tire wall. Go big or go home it will be fine
That was a changer,I will try it tomorrow with the string.Hope there 30mm + in spare ?
Did get other wheels,,19s got sold.
Got instead other Wheels,18s with 245/45/18 and ET 48 from a VW Passat.
