Bahnstormer_vRS
269
198
I have a conundrum.
I've had my Ateca VZ3 for a little over two months now and covered 1,750 miles a lot of which is stop/start and short journeys, having bought it at 6 months / 4,000 miles old i.e. total mileage approaching 6,000.
I've kind of got used to the brakes, Brembo calipers with 370mm drilled discs, being a little bit screechy when braking gently i.e. when creeping forwards in slow traffic, and that the pads appear to be 'high dust' .
What I was not prepared for is the (brake) dust getting into and blocking up the drilled cooling holes in the discs. :confused::confused:
My conundrum is two fold;
1. Is this issue typical or is it perhaps a legacy of the initial 4,000 miles when I suspect the car may have been driven hard (it was owned by Cupra UK), and
2. How best can I get the drilled holes unblocked?
For #2 I'm thinking of cleaning the holes by using, say, a 3.5mm drill bit (the holes seem to be 4mm) that's long enough to go through both discs or maybe punching the holes clean with a suitable, 6", nail.
Any other suggestions, knowledge or experience?
Guy
I’ve just done an internet search on ‘holes in drilled brake discs clogged with brake dust; is this normal?’ and it seems it is normal - reported on a number of other car forums by owners of performance cars fitted with drilled discs.
Try the above search - or similar search - as there are various suggestions on removing the accumulated brake dust. It’s also suggested on some forums that not clearing the holes of brake dust deposits can inhibit cooling of the discs, which can lead to micro fractures around the drilled holes with certain types of use. Probably more of an issue with activities such as track days if the brakes (whatever disc type) aren’t cooled down sufficiently after heavy use.
Reactions: Bahnstormer_vRS
@SRGTD - Indeed. (y)(y)
I did my research on the Interweb last night, after starting this topic/thread and have also, a few days ago, got advice from a very close McLaren & Porsche owning friend.
This is not a new problems with reports of 'drilled discs getting clogged' on PistonHeads and a Porsche Forum from circa twenty years ago. 🤨🤨
The consensus opinion to rectify, is to drill out the clag with a hand drill using a bit slightly smaller than the holes, precautionarily wearing a mask (I've got some of those left over from COVID days), but do not use a jet wash or compressed air.
I guess what I'm more interested to learn is, are other CUPRA VZ, owners not limited to Ateca but Leon & Formentor too, similarly afflicted in our lowly steeds (compared to high performance cars)?
Guy
Try compressed air if it bothers you. I have the same discs on my Leon Cupra, I don't care so much about this particular "problem" :) , has no effect on the cooling I guess.
Several holes on my discs are also blocked.
Common regarding drilled discs.
@TheSwede - Thanks for your suggestion.
I doubt that compressed air will work, certainly not at this stage to clear the compacted brake dust in the holes; which I can't poke out with a wooden pin or drill bit. Besides I haven't got access to a compressor, without going to a garage and using their tyre inflator.
As to the effect on cooling; I'm sure there will be a detrimental effect if the holes are blocked; if not, why have them in the first place. 🤨🤨
Guy
Main function I believe is to clear away gases and debris during hard track use. Cooling…very tiny holes, very little air through them.
They can cause cracks, which is not good at all.
Back when I was running Audi RSQ3' an amazing garage, The Phirm, down in Camberley, fitted EBC Redstuff pads for me, when they removed the stock OEM pads (the RS had covered about 15,000 miles by then) all the vent holes were clogged with pad debris. They painstakingly drilled out the old pad material - note the outer disk face holes don't usually line up with the inners....
UPDATE and an apology to @TheSwede for doubting that Compressed Air would clear the holes. It likely will, on my car at least, although it's not an option I will try.
Let me explain . . . . . .
After some further research, investigation and checking things over I found that the holes I thought were blocked were not actually holes but dimples in the disc. Looking at my original photos if one looks carefully the innermost 'hole' is a dimple as the central two or three holes (of four or five holes & dimples) can be seen to be only partially blocked. You get a better impression of this in the pic below, borrowed from SeatDirectParts.co.uk
Having established this, I then turned to investigating further unblocking the holes and realised that the drill bits I'd been trying to poke through had been too fat. Also, having chatted with the service chaps at my local dealer (I was visiting to have a small unrelated job carried out) they cautioned against drilling as it would potentially make the bore of the holes rough that would serve only to attract brake dust to stick. I therefore thought about fining something smooth to poke through.
A local supermarket was out of stock of BBQ skewers and then, by chance I can across some knitting needles (yup; don't ask). 4mm were too fat but 3.25mm would slip through the holes a treat clearing out the brake dust that wasn't clogged up after all.
Finally, in clearing the holes in the outer disc I came up with the point mentioned by @CosmicBlue. The holes on the inner disc don't line up. Argh!!
Presumably, the only way to get at these is to remove the disc from the hub; unless there's a gap in the backing plate I can poke the knitting needle through, but that would still mean getting the car jacked up or on a ramp and working from underneath.
Ultimately; I don't think I have as severe an issue as I first thought and, on balance, I'll probably have to live with and monitor the situation.
Guy
Reactions: TheSwede
...and also the dimples near center are very near by the the round rods that connect the center part to the disc part. Not good to have drilled holes there.....
@Bahnstormer_vRS - I understand why you cancel the operation, to much work compared to the gain. As I mentioned before, I suppose you can't tell the difference if you clean the holes.
@TheSwede
A good point about the position of the dimples.
Yes; I've cleaned the holes I can see on the outer disc today, as the wheels were off whilst a mobile tyre fitter was with me supplying and fitting new All Season tyres for the winter, and I trust that the holes in the inner disc are not blocked up.
As the discs are ventilated anyway, I reckon that by keeping the outer holes clear (easily done as I have now found out) this should provide enough cooling ventilation to do the required job on the disc.
You've said "For a regular street car, the holes are more of a decoration." which is true if I drive my Ateca as a street car, and not take it on track (which I'm not intending to do).
Overall, I'm happy with the situation and understanding of drilled discs. All I feel I now need are some suitable brake pads that are 'low dust'.
Guy
