Small update... spent a bit of time with the fuel pump tonight but didn't finish it off as I managed to leave the fittings at home... DOH!
Tony has been having a look at the downpipe and boy is it tight!!! new day, new problem... a power steering pump pipe is in the way. I have no pics as I forgot my camera too but its the one that comes out of the reservoir and down past the brake master cylinder. Its a flexible pipe part way down then goes hard pipe just past the MC and down across the subframe. This pipe needs to be moved to allow enough room for the DP to curve back out of the turbo.
Current idea is to remove this pipe and replace part of the hard pipe with hydraulic grade flexible pipe and route it out of the way to rejoin the hardpipe by the subframe. This should open up a nice space for the DP to live in.
Probably wait until Bill is back for a second opinion as I would rather we get this bit right.
<tuffty/>
<tuffty/>
Tighter than a nuns naughty bits
