Autochanger aggro
vee5
The glovebox mounted 6 disc OE autochanger in my V5 seems to have a problem recognising some CDs. When I load the cassette I check that all the CDs are the correct way up and are properly inserted but the HU normally displays an eror message like "CD error" or "no CD" for 2 or 3 of the CDs (especially nbr 2 for some reason).
This is starting to drive me mad and I dont really want the expense of changing the unit - any ideas on whether this is fixable?
BTW I'm using original CDs, not onces I've burnt.
BJM
739
Houston, Renfrewshire
How old is your unit? I've heard of this happening on some of the older units but usually with copy CD's. Have you tried the reset button (IIRC below where the cd cassette goes - push with a pen) or upluggng it from the Head Unit then reattaching it?
Deleted member 5241
These are crap and do fail after a while. The autochanger is really expensive through SEAT and AFAIK can't be replaced with an aftermarket one. One option is to replace the whole thing including the HU with something like an Alpine for about £140 + surrounds as the new one is slightly smaller.
vee5
Cupra kid, have you tried what BJM suggested yet? For various reasons I wont be able to try this for a few days and I'm interested to know it works for you as it sounds like we have the same problem
thesonny
UNV This
Nov 20, 2006
90
This happened on my old sony 10 disc changer, the anti-skip protection broke, and then it confused itself when it tried to use it and turned off. Nothing to be done if that is the case. :(
Rog.
...is unwell
Jul 19, 2006
93
Location Location
Got the same problem on mine - it's really intolerant of discs with the slightest amount of dirt/dust/fingerprints on them. It also doesn't like CDs with CD-TEXT, although the (Aura) head unit plays them with no bother at all. Sometimes if it doesn't like one disc, the whole thing will freeze up and display 'error' until you take the magazine out and stuff it back in again.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
I noticed something about mine the other day, when its very cold it gets worse, i have for the last few days had my cd changer constantly wrapped in my coat and it hasnt done a thing wrong since, maybe its condensation on the laser or something :confused:
Steveo1977
How old is the Car? I had mine do exactly the same thing. Took it back to SEAT under warranty. Swapped the whole autochanger unit for free.
This tends to occur if you use copy cd's in them I noticed!
Before I did that I checked out a few forums and a common answer is to try getting a new magazine. Ebay had some for about £15.
The other alternative is to replace the whole autochanger after warranty expires.
vee5
Just bin into a local independent auto elctricians and they said they knew the problem of not reading CDs only too well. Aparently the autochanger is made by Alpine but VAG knocked Alpine down on the price, so the transport is built to a very low spec.
The guy I spoke to reckons it can be fixed via a rebuild using better components for around a ton. Sounds like the best bet to me as I'm hacked off with not having all 6 CDs available - anyone else had any experience of this rebuild?
healy6660
Right Old Giffer
Mar 30, 2007
77
Cumbria
I know this may be a little late guys but have you tried cleaning the plastic covers on the disc selector forks
take out the cassette and look inside, you'll see 2 pieces of white plastic
get some solvent cleaner (like from a tape head cleaning kit) put it on a cotton bud then reach inside and clean the plastic covers on the fingers
apparently this is a big problem with these changers and the most common cause of this error message
worked a treat on the brother in laws and he now does it every 3 months or so no problems yet!
Nov 27, 2006
1,204
www.cardomain.com
Aparently the autochanger is made by Alpine but VAG knocked Alpine down on the price...
Rubbish :blink: (not doubting you, but the guy you spoke to is blagging it)
Not the Leon/Toledo one anyway ... they even have stickers on the back saying made by Matsushita (Panasonic)
Ton sounds a bit dear for a rebuild too, but I'm not about to offer it cheaper cos I know what a PITA they are to re-assemble - and I'm in no position to offer a warranty
Best advice - as above - is keep it clean ;)
vee5
Thanks for the advice - I'll try cleaning the forks as described , esp. as it will only cost 0.0001p for the cotton bud! :D
vee5
Cleaned the white plastic bits as suggested: hey presto - the autochanger now reads all the CDs!
Thanx for the top tip, esp as it saved me a ton !!
