autolock feature
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
ok, my 05 FR has the autolock feature...works fine and all. but is there any way that it will unlock all the doors when i remove the key? as it stands it only unlocks the drivers door..i just hate people trying to pull off my door handle!
simon34
smoooooooth
May 2, 2006
535
northampton
As far as i am aware if you unlock all doors (2 clicks) when you remove the key from ignition it will unlock all doors
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
There should be a button on the inside, near the window switch that has two pics on it, one for lock the other unlocks the whole car.
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
yeah, you can turn your selective unlock off with vag com, this wil mean one press of unlock will unlock all doors.
(Recode moduel 46 and ad 1 to existing code ie if code is 12345 recode to 12345+1 = 12346)
btw when the key is removed from ignition the doors will return to the state they were in before they auto locked IIRC
davels
soon 2B 2 wheeler!
Jun 16, 2006
1,193
Norwich
i think your right mate, if all the doors are unlocked before you pull away and auto lock, they all unlock again when you take the key out, just get in the habbit of doudle pressing your unlock button on the key before you get in.
Oct 17, 2006
2,141
Mid Wales
My car doesn't return the state before autolocking when I remove the key - only the drivers door ever unlocks, even if before setting off i'd opened all doors to let passengers in.
