hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
ok, my 05 FR has the autolock feature...works fine and all. but is there any way that it will unlock all the doors when i remove the key? as it stands it only unlocks the drivers door..i just hate people trying to pull off my door handle!
As far as i am aware if you unlock all doors (2 clicks) when you remove the key from ignition it will unlock all doors
There should be a button on the inside, near the window switch that has two pics on it, one for lock the other unlocks the whole car.
yeah, you can turn your selective unlock off with vag com, this wil mean one press of unlock will unlock all doors.
(Recode moduel 46 and ad 1 to existing code ie if code is 12345 recode to 12345+1 = 12346)
btw when the key is removed from ignition the doors will return to the state they were in before they auto locked IIRC
i think your right mate, if all the doors are unlocked before you pull away and auto lock, they all unlock again when you take the key out, just get in the habbit of doudle pressing your unlock button on the key before you get in.
My car doesn't return the state before autolocking when I remove the key - only the drivers door ever unlocks, even if before setting off i'd opened all doors to let passengers in.
