kris_tdi
108
Hi Guys, im having an intermittant problem with the lock on my passengers door. It locks fine off the key or remote locking, however the autolock when you reach 10mph or whatever its set too it locks and unlocks randomly as you go above and below this speed. Is there a relay or interface which could be at fault here?
Kris
Reactions: mjstokes85
Found this old thread and thought I'd resurrect it.
Mine does something similar. Once you exceed 10mph or whatever it is the doors lock automatically as they should, occasionally when i slow back down to say below 20, the passenger door, unlocks and locks.
So if anyone knows what the issue is, any help would be much appreciated?
I have the same its not very often but a bit weird when it does do it
My seat doesn't auto lock aþ 10mph, locking via driver door outside its fine, do it via the button inside it locks then unlocks. Iv got a second motor from a scrap yard from an 05 ibiza, may change it over.
