Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
As far as I can tell from the diagrams, it is in the thermostat housing, which is a separate manifold attached to the end of the block, where all the coolant pipework comes together. The radiator top and bottom hoses are both attached to this, as is the heater matrix feed and return, the header tank and the water pump.
Is the thermostat housing the huge diamater hose between the engine and battery? Where many hoses come together?
That sounds right, but I dont have an AZD to look at. Can you get a picture for us to look at?
If this Huge Diameter Hose thing is metal, it is what I'm describing as a manifold (for want of a better word). The thermostat is inside it, so not visible. but the temperature sensor should have an electrical connector and some wires going to it.
