Back brake discs
Space-Black
84
Northants
My Leon's due it's MOT next month and the back brake discs are slightly pitted and one has slight rust when it's been standing. Do you think this will be a failure? Also, if so, how much approx should new back brake discs cost?
Also on the MOT - it has a chip on the windscreen that's quite large - about the size of a 20p piece - but it's really low down, almost level with the windscreen wipers. Driver's side. I'm going to ring my insurance to get it repaired but I can't really afford to get a windscreen at the moment - do you guys think this will be an MOT failure as well?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
i don't think either will be a failure. i had 3 chips in my screen last mot and it passed ok, i think as long as they are not in your vision field it is ok. As long as your brakes work properly there shouldn't be an issue? give it a good run to get the rust off first. i'm no expert tho! just offering an opinion.
Space-Black
84
Northants
It's not so much the rust as I'd run a wire brush over it but the fact they're pitted. When it had it's service last week they noted it down though they didn't try to tell me they needed changing, but my Dad who's a mechanic says they might fail.
Hmm, might ring insurance and get their opinion. Cheers mate!
theyellowone
I think so long efficency/braking effort passes its fine. If the rusting is excessive, yes braking performance will be lowered....depends on how bad it is. But driving the car around will soon rid of surface rust.
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
They are stupid cheap IIRC dude, and not a bad job to change them either (caliper winder and a screwdriver)
Jimski
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
if 256mm vented rears - £58.89/pair
if 233mm solid rear - £27.95/pair
prices plus carriage & vat
if only rust and performance is ok, without an edge which looks like it is flaking apart badly, then you should be fine.
10mm diameter max on chips if in swept area of windscreen is your limit i believe
