Badger 5 remap stopped working.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,014
66
Hertfordshire
So just picked up a car with a badger 5 remap, was shown how to switch between them and all was well.
On the way home it stopped boosting past 6psi but all seems fine. It’s like it’s stuck in the stock map.
Anyone know how to reset it or something to try as it’s running fine just in stock trim. I’ve tried dealing the maps over.
Sparkie
Angling Adict.
Sep 25, 2009
2,539
776
Middlesex
Fuses for the switch? Or a new switch needed?
Have you called the guys at Badger5.
Great bunch. Worth calling and asking their professional advice.
Badger5 Custom Map + TIP,
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,014
66
Hertfordshire
No wanted to see if I was being a Wally first and there was something I could try before phoning them.
Sparkie
Angling Adict.
Sep 25, 2009
2,539
776
Middlesex
I’d not bother with o5her people’s guess work and call Bill and the lads strait away. Get their input. It’ll be best advice.
They are a very approachable bunch.
Sent from my iPad using Tapatalk Pro
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,014
66
Hertfordshire
Cheers. I’ve been told 5 psi is limp mode so need to see if I can get it scanned first then will give them a buzz.
Sparkie
Angling Adict.
Sep 25, 2009
2,539
776
Middlesex
Yes I forgot to say that’s limp mode territory. Mind on other stuff.
When. Was water pump last done? Can easily be the cause.
Or a Ton of other stuff too. Yes scan is the best starting point.
If running without spluttering then coilpacks and sparks should still be good.
Good luck.
