*Battery/Alternator Warning Light Help*
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
My Battery light on dash has illuminated twice in total.
First time was 2 weeks ago when i was really giving it some, it came on as i braked hard for a T junction. It came on and went off for no more than 2 seconds, it then stayed off.
Today driving home from work on dual carriageway pulled out to overtake and it did the same, popped up for 2 seconds max then went off.
Car doesnt feel any different, and i didnt investigate further after 1st incidence as it didnt do it again.
Just checked manual and it says its the Alternator warning lamp.
"if comes on although the v-belt or ribbed belt is not broken or loose, one can drive on to the nearest technical service centre"
"if warning lamp lights and the belt is loose or broken DO NOT DRIVE ON-the coolant pump is no longer being driven. The belt must be checked or renewed"
Had a quick gander at all belts and nothing is slack or loose or worn. Could anyone direct me to the particular one??
Anyone had any experience of this?
Would this be a sign to replace the cambelt/waterpump/impeller etc?
R
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Ive got a tester which you plug in your cigrette lighter, tells your battery voltage and altenator voltage. Which may come use full to see if you alternator is playing up or not! Cost me around a £10 around a year ago
DodgyDave
121
Glasgow, Scotland
Now dont shoot me down here :)
but are you sure it was the battery/alt light and not the oil light ??
Reason is that under heavy braking the oil will move about in the sump, if the level is a bit low you could get this. Would not think accererating would do this though......
Dave
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
ive got board meeting all day
what are you doing tomorrow night?
dodgydave- 100,000% not the oil light
plus car was only serviced last week
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
update
had it on VAGCOM-no codes at all for this????
tested battery and Voltage is perfect when off and at idle, drawing the correct amounts
took off terminals and check and all are clean as a whistle?
belt is tight and good cond
anyone any idea's now?
just going to have to keep an eye on it i guess.......
DodgyDave
121
Glasgow, Scotland
No probs ... as both are red and ony come on when you are pushing it's not always easy to see what one it is :)
I'd go for a loose earth from alt-engine myself, it sits quite low and can get soaked and start to rust, then any movement sets it off......
Dave
Wallis22
282
Sorry to bring up an old topic, but i need to check my altenator. Can you remember where you got it from or what it's called? Thanks.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
Ive had this happen a few times wen givin the old girl sum beans the battery light comes on and then off,dun it a few times and ive looked in to it but can not find any problems so left it alone.its always been fine since.
