Shrekker
36
10
Can anyone tell me a better front discs and pads for a 2017 Leon FR 1.4 ACT , I find the braking not very good
Also what size diameter do i need please. Euro states that there is two types of discs to fit my car ?
Do you think the Brembo are better than the others ?
I find the brake pedal a bit low , despite bleeding etc, my other leon 1.2 2016 has a better brake feel
Steve
Steve
Your brakes on your car depend on your PR codes. Can normally find a sticker with your PR codes in the boot - or in your log book.
example:
276x24 = PR-1ZF/1ZH (continental brake system)
288x25 = PR-1ZE (TRW brake system)
312x25 = PR-1ZA (TRW brake system)
No Brembo 'aftermarket' are not better.
Sounds like you might have a brake system issue.
Check for seizing/sticking - caliper pistons, slide pins, pads are not tight in the caliper carrier. Are you 100% you have no air/ is the brake fluid old? When fluid gets old it absorbs water which then evaporates when it gets hot which can give you a soft pedal.
