Yes pretty sure you can. Go on the seat accessories website.
Aftermarket ones are still sitting at over £200 a pair - http://www.carparts-tuning.co.uk/Li...t-Daylight-Seat-Ibiza-Typ-6J-Yr-08-black.html
OEM xenon headlights are usually £250+ EACH - then you need the rear axle sensor for the auto leveling etc.
the auto levelling is only technically required from the factory, you can fit them after without the sensors and they will still work, and you would be unlikely to be pulled up on the levelling.
Until the MOT where the self leveling and the headlight washers will be checked even if you self fit the xenons
Having had xenons on my last two cars, I can tell you that they don't check those systems at all, as I was advised seperately when I had a failed washer jet as it's not a part of the MOT
I'm pretty sure the washers are part of the MOT, if they are fitted they must work but if they are not fitted you get your MOT!
That was my understanding too, but when I MOT'd the car in January I was told that they don't check the headlight washers, only the windscreen ones! Thought it was strange, but took the tester's word for it!
I think you MOT tester was being kind to you mate. See below taken from the MOT manual.
I was told it is just down to the power of the xenons / HIDs compared to halogen.
