Checked but it looks ok. Did'not know this was a seperate error, because VAGCOM counts it as 1 with the 16487 error.
Today we're going to adjust the wg-actuator to reduse the boost a little. Hope it helps. Also going to install a new dogmount (ECS) and going to replace my Denso plugs and try the Bosch i bought from Awesome.
hi msterD2010, i defo agree with this. think the wastegate may have too much pre load on it hence why its exceeding the requested boost and causing limpmode. try turning the actuator rod back a few turns and you may well findit stays within parameters better. the ecu watches the boost produced plus i get the maff signal too high but doesnt cause limp mode. second fault code seems like the culprit. keep us posted and good luck mate as seems you've been thru a fairly heavy time with the car.
gulzar.
