Yeah rear seats are pretty easy to get out, start with the one on the right as it's not as heavy. On the right side near the door , the bolt coming out of the seat is latched in, just lift the latch up and you can remove that side, then wiggle the left bolt out. as for the bottom lower seat, simples. just flip it over and push the bolts held into the car out. Do the same for the other side but this time the seatbelt is attached to the seat so get a 17mm socket (i think and undo the nut that holds the belt in place ( might need a proper socket wrench thingy like you use on the wheel bolts). Undo, pull out, spray seats, make a mess of patio (I might need to power wash it soon woops
