Hi,
Do you know if the 2GO code means its a rotary pump engine?
There is some confusion as the handbook says it is compatable if its got thr 2GO code, howerver a seat representative says that no seat TDI in the current range is compatable.
I have two areas of concern with using bio and why im not (although would like to) which are the injectors and dpf.
As the active regeneration allows unburnt fuel into the dpf to burn (although is probably a catalytic oxidation recation as opptosed to combustion) there to raise its temperature, its possible that the bio-diesel wont burn properly and lead to poisoning of the catalysts in the filter.
All though the seat traning manuals the only reference to bio is with regards to emissions control. There is never any mention of the damage it can do or negative effects on the system. Even in the DPF sections it just says that the use of bio-diesel makes it impossible to guarantee the emissions will meet the nessessary standards.
Theres what SEAT customer relations says, what tecnical manuals say, what user manuals and what people expereince, none of which seam to match!
All the more reason now to save on my fuel bills. At least the skiing holiday is paid for.
