the advert says the bulb should have a life span of
Flex Strip 12V White Wide Angle £10.58
Click to enlarge
Flex Strip White - 12v
High intensity LEDs. Standard strip length 360mm. 12vdc. Single string 24 LEDS with 15mm spacing. Very flexible, comes with mounting clips which can hold up to 2 strips side by side. Can be cut at intervals of 45mm. Multiple connector sockets and connector cables allow easy connections between strips.
Strips can be cut every three Leds and joined with connectors.
Ideal for accent lighting, channel letters, sign boards etc. Supplied with clips and connector cables. Power consumption 1.6w/per 360mm Strip. LED life: Up to 100,000 hours.
