rsmith
Robbie
Apr 28, 2004
2,796
Tipperary, Ireland
Hey All,
I did some quick logs today, 4th gear runs, everything looks ok but block 020 has me confused, Can someone look at the below log for me and tell me if the cyclinder timing is to much and what is normal, please bear in mind my ECU is remapped.
Thanks in advance.
Code:
Group A:	'118				Group B:	'020
	RPM	Temperature	Load	Pressure	Degrees	Degrees	Degrees	Degrees
TSTAMP	RPM	°C	%	mbar	TSTAMP	CF	CF	CF	CF
0	1680	33	0	1000	0.62	0	0	0	0
1.22	2080	33	0	1030	1.83	0	0	0	0
2.42	2320	32	0	1100	3.03	0	0	0	0
3.62	2040	33	95.3	1340	4.25	0	3	6	3
4.95	1480	32	95.3	1260	5.54	0	3	6	3
6.15	1760	32	95.3	1290	6.85	0	0.8	3	0
7.46	2080	32	95.3	1420	8.06	0	3	1.5	3
8.66	2440	32	95.3	1790	9.28	3	3	4.5	2.3
9.89	2920	33	82	2540	10.57	2.3	2.3	3.8	2.3
11.26	3520	33	85.9	2370	11.88	2.3	1.5	3	1.5
12.49	4080	34	86.3	2450	13.1	1.5	7.5	3	4.5
13.73	4600	36	91.4	2450	14.8	4.5	7.5	6	7.5
15.41	5200	39	95.3	2290	16	7.5	6.8	9	6.8
16.73	5560	42	0	2540	17.43	3	6.8	9	2.3
18.03	5640	41	0	1530	18.74	0	0	0	0
19.33	5520	39	0	1040	20.03	0	0	0	0
20.63	5240	38	0	1020	21.22	0	0	0	0
21.84	3880	37	0	1030	22.52	0	0	0	0
23.15	3760	36	0	1030	23.85	0	0	0	0
24.45	3440	36	0	1020	25.16	0	0	0	0
25.77	3120	36	0	1020	26.35	0	0	0	0
26.96	2840	35	0	1020	27.56	0	0	0	0
28.28	2760	34	0	1020	28.96	0	0	0	0
29.59	2680	34	0	1020	30.27	0	0	0	0
30.89	2640	34	0	1020	31.58	0	0	0	0
32.19	2560	34	0	1020	32.9	0	0	0	0
33.51	2520	34	0	1020	34.19	0	0	0	0
34.92	2440	33	0	1020	35.61	0	0	0	0
CF look too high to me .I thought idealy no more than 3 for the most of the block with,slightly higher at some points. What petrol are you using?
Was just snopping about and spotted this thread. In the Vag-com logs what is Degrees CF?
Is this something todo with ignition timing depending on what the knock sensor reports back?
Ive got a TDi so the answer probably isnt of any use, im just curious as i think ive worked out most the meanings of things.
stuart
