does the bmc-cda and 007p combination make much of a noise?
  • Total voters
    14
right so the verdict is that it does make a noise then? i dont want CHAV just want a little bit of a noise that i can hear with the windows open or shut to keep me happy
bmc/ram air/dynatwist/modshack + 007p dv = louder induction in car with subtle DV noise... sounds good :yes:
but with the windows open you will struggle to hear the DV at all!
open cone filter with 007p dv = loud induction roar inside and outside car including DV noise! (if u make ur DV dump whist driving passed people, THEY WILL turn and look! ;))
the decession is yours!
right can someone give me a straight yes or no answer cause i am easily confused lol, will it be loud enough to keep me happy?
thing is if it aint i can always buy the spplit r
Forge DV + BMC CDA = Quieter whoosy (more subtle than anything)
Baileys DV + BMC CDA = Whooosy all day long on the LCR
Forge Split R + BMC CDA = I can only imagin that it will be the loudest combo out there, but then you could use the split R with an open cone.
Jus my 2p's worth from my experience :D
Forgetting the whooshyness of this post... be aware that an open cone filter is very likely to suffer from heat soak and may potentially reduce power, especially at lower speeds.
If you want performance and noise, follow coxw's advice and invest in a Split-R valve. It's loud enough to make a noise, but safe to use with the 1.8T engine. Combine that with a decent enclosed induction kit and you have the whoosy noise you want without heatsoak and reduced power.
The deal is the Carbonio won't fit the LCR
You want louder than the BMC CDA then buy the RAM AIR or the Dyntatwist
(And yes I have tried all the above with a Forge 007 and Bailey DV30)
excellent. somone whos used dynatwist.
so the dynatwist is louder? intresting.
which had the nicest , deepest induction roar?
bmc or dynatwist?
J@mes, please dont take offence to this if your not, but are you Ralf Little (the guy who plays Johny in two pints of lager...) You just look a bit like him in your avatar pic.
pmsl couldnt agree more :clap:
LMAO!!! :lol:
no i dont look anything like him I can gladly say! :yes:
