Boost gauge readings
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
What are normal boost gauge reading all around?
Not sure whether my gauge works well or not. Idle vacuum seems to fluctuate buy never drops below 11, which seems low.
But I do hit peaks of 16/17 when under max load so that makes sense.
What should I be expecting from the LCR?
shnazzle
Sep 9, 2011
3,480
Northumberland
I got the APR tap. So straight off the inlet mani pressure. (mk2)
Idle should be at about 20-25.
When you let go of the throttle it should shoot down a bit lower than idle but climb back a bit. It just depends how much the throttle plate is open. If you're cruising with 10% throttle or something you may be at 0 or 5inHg.
Boost on mk1 is probably about 13 or so?
monk3y303
403
bradford
Qell its just one hose into the fpr and then 2 wires for the light but ill get pics if u want . Was expecting it to sat at 0 when idle and when throttle increase the needle goes up but working backwards lol
monk3y303
403
bradford
This is idle
shnazzle
Sep 9, 2011
3,480
Northumberland
Thought so... That's a vacuum gauge mate. So yes, the more you hit the throttle, the less vacuum you will pull. If you have a turbo... You want to get a boost gauge. That shows vacuum and boost.
shnazzle
Sep 9, 2011
3,480
Northumberland
Hahaha. It's alright mate. We all make mistakes. Good news is you're pulling good vacuum at idle which is a good sign.
If you replace this gauge with a boost gauge I can buy this one off you :)
monk3y303
403
bradford
Well not all gone to waste then lol ill be gettin a new gauge at end of month only problem is not guna match my other gauge now as there both the same ha
shnazzle
Sep 9, 2011
3,480
Northumberland
Shouldn't be a prob. Good chance the same maker makes a boost gauge. If your current one is electric, get another electric one. If the boost tube goes straight to the gauge, you only need to switch the gauge. Easy peasy
