You need something which will fit tightly to the mouth of the TIP (turbo inlet pipe). Some have used tennis balls, hair spray cans, an expandable bung, I actually used the end side of a water bottle. You just need to make sure it is tight and no air is being leaked from here. Then disconnect feed into n75 valve and apply air via this hose, connect both remaining n75 pipes together. Take off the oil filler cap and pressurise the system to around 10 psi as you do not need too much pressure. Then its simply a question of listening for any air being lost in the system
