danarmstrong
175
South Wales
i am running 20psi boost but lately it will not boost past 10psi, its doing my nut in, have checked all boost pipes ect but still no joy, anyone else had any simular problems?
please help!!!
Have you got vag-com to scan for codes, Is your engine management light on ?
Mines used to do this when it blew a fuse under the steering wheel
Does anyone kno if the lambda sensor could cause me problems? Coz I decated it last week and there are two lambda sensors, one before Nd one after the cat so I unplugged the one after the cat. Just wondering if that could cause me problems,
if there no relative codes pointing to the cat den m shudnt tink so had my last lc de cated no problems, are u running standard bosch recirc valve ? n might wana give n75 a check had the same issue last year turned out n75 was nackered hope this helps
Well I will give the lambda a go n just plug it in n see how it goe, can't do any harm can it, got a forge recirc valve, ain't checked the n75, was hoping to get time to bypass all the n75 and n249
Well if you remove a lambda then the engine wouldnt be running right? Most people get the 2nd lambda mapped out. Did you check the fuse I told you about?
Yer mate checked that fuse, all fuses are mint, gonna try plugging in the lambda sensor n reset the brain n see how it goes otherwise Fuk knows lol. It's had a jabba stage 2 custom map so that should be mapped out
Does anyone know where n wot the n75 looks like n where it is on the rocker cover coz got a couple of sensors there n bit confussed.com haha
Well just fitted new n75 sensor and still only boosting to 10psi WTF gonna burn it I think haha, anyone got any ideas n I don't mean on burning it lol
