Boost spike problem, with video..(fixed page3)
Dec 20, 2007
505
No it doesnt log, just fault codes i think. :(
Is 22 psi just a light load then ? as my guesimates were a bit off, it only does it if i go flat to the floor in a a higher gear at 1.8k rpm ish, anything above 2.3k rpm it spikes at 22 ish and pulls all the way through.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Sounds similar on the video to my problem, i've been told that mines a boost leak, but yet to find it
Get some logs done and then can see what your boost is requesting
Dec 20, 2007
505
Got any video's of yours Boris ? what i find wierd is its peaking fine, its on the way back down it does it, like ti will peak at 26psi, then when it gets too 23psi, it will make that noise etc..
Rob.
Dec 20, 2007
505
Oh right, mine smooth as you like as you can see from the video when the boost is building up, it peaks and it does it just when it starts coming back down.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you will see %load on vagcom.
block 115 request vs actual boost
Dec 20, 2007
505
Still no vagcom :(, i can confirm this only happens in 3rd or 4th, had it spiking to 24psi and holding for a little in 5th tonight, and doesnt do it in 1st or second, if i can get my revo turned down from boost 9 what would roughly be 22psi ? about boost 7 ?
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
i had the 'brrrrr' sound last night that you were describing r8byb.. i've got a forge tip so the spool is louder, i can hear it spooling, it comes on boost, no idea at what psi as I don't have a boost gauge, then it would just be rapid for a few seconds, torque steer etc... then it would fall over, limp mode. No lights or anything- just no boost at all. After a few seconds it would come back on boost. SO annoying. According to computer- 2.5 degrees outside. But it used to happen in 10-20 degrees in summer.
So annoying!
Dec 20, 2007
505
I see, no idea what it is then ? My mate and a few others seem to think it could be a coilpack/spark plug.
You have the exact same noise in my video then ?
Anyone else got any input on whether it could be coil or plugs causing this, hopefulyl have vagcom next week.
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
well, this weekend im changing n75, plugs, coilpack and MAF... then it's being serviced- just to be sure! (It's due a service anyway)
I'll be so annoyed if it's the same afterward haha!!
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
I have worked on an RS4 with this problem before too. That was also remapped.
It would pull really well but once it had spooled up, it would do just the same, it didn't go into limp mode but it would back off a bit and judder. (Nothing to do with traction control in this instance either)
When I looked at the boost curve, you could see it spooling up and then it would spike and then fluctuate.
He got the boost turned down in the end and its fine now.
Dec 20, 2007
505
Well let me know how you get on, You going to change one at a time then try it ? so you know the problem ?
My mate reckons the spark is burning out at high boost causing the brrr brrr noise
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
Well this is the thing- everything part wise could be ok... i think the actuator has been fiddled with by someone in their garage or something (previous owner), and instead of researching the tuning on them just had a fiddle instead. That's why i'm taking it to a vw/audi specialist asap to see exactly whats been modified!
Dec 20, 2007
505
Ok, just count the threads on the actuator, should be 13 i think, i counted mine yesterday and its standard.
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
yeh will do! hopefully its just something simple like that! do you have to see it from under the car?
