boost
ibiza turbo
58
hi i have a ibiza 20vt which runs 12psi is there a way you can turn the boost up via actuator ??? just want it to boost 15psi:p
steveturbo
71
Mine peaks at 18-19 psi with stage 1 the best actuators are the standard items for these engines.
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
not sure about that to be honest on standard map these can spike to between 8-12psi , its where it holds is crucial , should be hokding around 7-8psi mark
cuprawill
Turbo lag is foreplay
Nov 20, 2009
703
Standard map shouldn't spike anywhere past 8psi max. 12psi points towards a mapped car with problems
Sent from my HTC Desire S using Tapatalk
Apr 12, 2008
539
yes, u can play with actuator, it cannot harm ur engine, but u wont be able to make more boost...maybe only peak boost (boost spike) and if u wind it up 2 much u will have limp mode..
ibiza turbo
58
previous owner told me it use to boost 18psi but he had it turned back down to 12psi it holds 12psi all the way to the rev limiter too cant wait for it to boost 18psi
