Nov 22, 2026
Hi guys.
Recently bought a 2009 seat Ibiza 1.4 petrol for my son as a first car. When I bought the car, I knew it had a problem with the boot not opening. Gained access with the back seats down and tried the emergency release with the key as described in the manual but still wouldn’t open. So popped the trim off and had complete access to the release but someone’s obviously been in there before as the release don’t work and it just felt loose in there. So my question is, is there another way to get the boot open ???
With the trim off you can bypass the slot. The emergency release just slides a lever on the latch itself, so if it feels loose that link has probably come off. Move the lever with a screwdriver while pushing down on the lid to take the load off the catch.
We had a similar issue with our 2010 Ibiza.
Dealer said was caused by water ingress through the glass seal, but Autoglass said it was fine which I was pleased about as the spoiler would have needed to come off and its bonded on, so 2ould have been a nightmare.
I ended up buying a whole new boot release from Amazon part No. 6J4827505E9B9. Was easy to fit even for me lol.
We also had the rear wiper come on by itself, and I ended up just taking the fuse out.
My main problem at the minute is getting the boot open as the white plastic lever that opens it in an emergency looks like it’s come off as it’s loose in there and don’t do anything. I’m going to have another look when I’m home in daylights hours and I’ve just ordered a replacement latch to replace it when I do get it open.
Reactions: Rob66
OK mate good luck with it, I'm trying to remember how I did it, think I used some thin pliers to grab the wire, had to lay on my back in the car with a torch,
