slamka33
320
8
Formentor boot space is by Cupra "defined" as:
  • 2WD - 450 l
  • 4WD - 420 l
  • PHEV - 345 l
I understand 4WD & PHEV takes some space from the boot, but in case of 2WD - is 450 litres valid for upper position or lower position of the floor??
I have a "bad feeling" in lower position, while for 4WD the floor is only possible to have in the upper position. Am I right? That's the reason why 4WD has 420 litres...
Why am I asking - there are another conditions, in case of 2WD, which prevents floor to lower it to lower position:
  • Sound system
  • Top View 360 camera system
Both systems has a "devices" placed in a foam on right side next to the spare wheel, like on this pic (this one is only 360 cam, sound system is missing, but it has another device with bunch of cables closer to the backrest):
img_2197-jpeg.46524
The dealer is not able to tell me, only repeating that 1.5eTSI has 450l boot.
But with sound system or top view camera, the floor cannot be lowered..
So? I am really confused now. And as you can see in my signature, I am used for 600-620 litres boots... so considering "each liter"..
Thx for your help guys.
Right now I saw this video of PHEV, where is mentioned 345l.
But what drives me crazy is the video of the boot then, which looks exactly the same like for 1.5eTSI with higher position of the floor. :eek:
Can someone make it for once clear for me??
I can tell you of 310bhp formentor with space saver wheel and sub, It's just one position.
Although I had somewhat similar car Audi Q3 2020 with space saver wheel and a sub.
You could change the boot floor position without issues.
I guess the picture you uploaded is the correct representation of how it looks.
Did anyone tried to move above mentioned electronic systems (sound system & top view camera) located in the foam somewhere around the spare wheel?? Is it manageable, possible?
Then removing the foam would allow the floor to be placed at lower position.
