Brake discs advice needed
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Should be upgrading the new disks this week as the MOT is over a month away. The front disk will be drilled and groved.
Abit stuck, on the brake discs sizes.
fRONT DISK
What size disk does my leon take (1.8T sports 2000).
Done a quick measure ment, it coming up approx 32cm (see pic). measured straight through the middle of the disc.
Rear
Does the rear disk look fine?
I know the pads will need changing for sure. :think: but not sure on the disk?
The MoffMeister
Half Hoff, Half Moff.
Apr 4, 2006
2,937
colchester
wher the pad rubs it creates a lip as bill says basically the top outer edge of the disc will be alot fatter than the rest of the disc where the pad runs
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
spongy pedal is as likely fluid and hoses
handbrake work ok? how many clicks before it holds?
rears looks just over 50% gone
Big_daddy
Oct 20, 2006
3,930
Brummy
The hand brake is crap, goes up to 3clicks, plus some time it rolls with hand brake on :cry:
So is the rear pads causing spongy brakes?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
fit new pads... ~£35/set for good quality ones..
you adjust the caliper (need the wind back tool) to get just a little clearance to slide caliper over new pads, then you will likely find handbrake is much less movement
